Rear Shock Rebound - Factory Setting on LTX-LE QS3R?
Owners Manual states 1/8" to 1/4" spring preload on page 36.
Center shock spring pre load.
View attachment 143510 Center shock spring pre load.
Dont forget those specs are based on a sled with junk Tuner skis. that setting is so your useless skis dont push into a tree with any loose snow. Put good skis or fix the tuners and you can really lighten up the front end by turning the center shock spring tighter.
