Team Yami
- May 26, 2015
- Upstate New York
- 2007 Yamaha apex gt
Have a low mile Sidewinder that has moisture in the speedometer. Was wonder if the viper speedometers with work also if the miles are stored on the gauges or the ecu. Also does anyone have a speedo for a Sidewinder with low miles on it they would sell??
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Did you try drying it out?
I have a 2019 winder dash— 3800 miles— yes mileage is stored in dash not ECU— call for more info if ya want 2607019033 Tod
Team Yami
- May 26, 2015
- Upstate New York
Yes I did, it helped but didnt 100% fix itDid you try drying it out?
Team Yami
- May 26, 2015
- Upstate New York
Okay I’ll keep you in mind Tod, I’ll try and run the one I have now as long as I can to keep my lower miles. Just hate to put a higher mile speedo in a low miles sled for when I want to sell itI have a 2019 winder dash— 3800 miles— yes mileage is stored in dash not ECU— call for more info if ya want 2607019033 Tod
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
My father bought a sled that was in an accident, she issued, we replaced it with a ns1 gauge. He is a very happy camper now that I've shown him how to use it lol
Here is another idea—- put the dash in a redux machine— one of my friends invented this machine— not sure if the dash would fit— it’s used for cell phones and hearing aids that get wet— put it in the machine, creates a vacuum then boils the moister off without hurting the electronics—— when you create a vacuum environment then the boiling point is lowered signifantly—- redux can be found at Verizon stores and hearing aid places—— just not sure the dash will fit in the redux box—- Tod
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
You could probably make one pretty easy.Here is another idea—- put the dash in a redux machine— one of my friends invented this machine— not sure if the dash would fit— it’s used for cell phones and hearing aids that get wet— put it in the machine, creates a vacuum then boils the moister off without hurting the electronics—— when you create a vacuum environment then the boiling point is lowered signifantly—- redux can be found at Verizon stores and hearing aid places—— just not sure the dash will fit in the redux box—- Tod
Do you have a food saver machine? Or know of anyone with a vacuum pump?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
The problem with a food saver is that you typically cannot pull the vacuum for any duration of time. You can use an air powered vacuum venturi and a compressor and pull vacuum for as long as you want or until the compressor keels over. Stick it in a sealed container, plumb in a vacuum venturi, stick the whole thing in semi warm water, and bobs your cross dressing aunt.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I was thinking more of just using one of the bigger containers that come with the food saver kit then pulling @ 29 inches of vacuum for a while with a vacuum pump.....The problem with a food saver is that you typically cannot pull the vacuum for any duration of time. You can use an air powered vacuum venturi and a compressor and pull vacuum for as long as you want or until the compressor keels over. Stick it in a sealed container, plumb in a vacuum venturi, stick the whole thing in semi warm water, and bobs your cross dressing aunt.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
It will work if you can keep the vacuum long enough. It actually takes awhile. While water has a lower boiling point in the liquid, it also doesn't have any atmosphere to carry that moisture so it takes a long time.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
This is how we remove moisture from A/C systems. Just let the pump run as long as it needs to remove the moisture.It will work if you can keep the vacuum long enough. It actually takes awhile. While water has a lower boiling point in the liquid, it also doesn't have any atmosphere to carry that moisture so it takes a long time.
- 22K
