morepower=morefun
- Nov 16, 2015
- Upstate, NY
- SR VIPER Turbo by Ulmer Racing, NYTRO XTX Ulmer Racing Stage 4
Anyone know more about the 9 ECU sensors? Trying to get to bottom of the track speed sensor function. Was told that the track speed sensor will assist in limiting track spin on "hole shot" or "launch" for a more controlled power delivery. I was told by Yamaha Sales rep today that the sensor does not communicate in that way what so ever, that there is no "traction control" or "power limiter" at launch. Can anyone give any insight on this? Why have it then? When I noticed no oxygen sensor in exhaust and commented, this same sales rep said "Oh its there... I'm just not sure where", so obviously that is why he is in sales....
Thanks for any help explaining.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Wow.....
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Apart from the engine designers, it sounds like you are currently more knowledgeable about the Sidewinder than anyone at Yamaha. Looks like your gonna have to find the answers to your questions yourself. Your answers might have to wait, until you get your hands on one.
GeFeldz
- Jan 27, 2009
- Sweden
- 1990 Aktiv Alaska XT, 1987 Ski-Doo Escapade, 1991 Polaris Indy Supertrak, 2011 Yamaha Apex XTX 1.75
The track speed sensor is very probably the same speed sensor that feeds your speedo, they've probably just tied it in to the ECU for some control function as well as to give data to the speedo. It even said track speed sensor (drive shaft) in the pdf about the engine package.
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
It would require two speed sensor inputs. By comparing those inputs is how traction control
functions. ie a car has speed sensors on every wheel. Just one will only give speed.
morepower=morefun
- Nov 16, 2015
- Upstate, NY
Yes, I agree. As with the street bike TCS, it works off the difference in speeds between front and rear wheel speed. My question arose when a Yamaha rep tried to explain that the Sidewinder will launch better (more controlled, less spin) than the Viper MPI Turbo kits due to the new 9 sensor ECU. My questions were "answered" that day by telling me that the speed, crank, TPS and boost sensors would tell the ECU to back off the power as the track spin increases through backing down the boost. This confused me a bit because I couldn't figure out how the ECU would know if the track was biting and just rotating or if it was actually losing traction with only the one driven shaft sensor. So now I'm left to believe that if there is truth to the claim of "more controlled, less spin at launch" then one would have to assume that the engine timing/fuel management mapping itself is designed to limit or deliver the power/boost more gradually than the Viper turbo mapping.It would require two speed sensor inputs. By comparing those inputs is how traction control
tapex_07
- Feb 15, 2009
What about when you add studs or traction adders? Just thinking out loud..
pdiddy
- Oct 12, 2004
- Southern Maine
- '18 Vector 129", '18 Indy 600 SP
Yamaha has it's own GPS satellite to compare track speed to vehicle speed on the Sidewinder. In the unlikely event a vehicle approaches from behind, a signal is sent to the SAC and it is destroyed. However, if a Ski-Doo is detected, there is a 300ms delay in case it self destructs (this was cost saving compromise).
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
My guess, based off how ECU's work, Is that there is a table that has set values for how fast the sled can accelerate and if the track speed indicates a speed above the preset line it cuts boost to regain traction. It might be a "gotcha" type hangup for future Highjackers or people adding more boost since it would be easier to accelerate the sled fast enough to push the system past that line. It would be sweet to have a TCS button to turn it on and off, I'd use the system on icy trails for sure, and OFF in the powder.
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Is still needs something to compare. How else would it know the difference between track spin/speed and
actual vehicle speed/acceleration?
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
[QUOTE=" So now I'm left to believe that if there is truth to the claim of "more controlled, less spin at launch" then one would have to assume that the engine timing/fuel management mapping itself is designed to limit or deliver the power/boost more gradually than the Viper turbo mapping.[/QUOTE]
Exactly. Smoother more controlled power delivery not a actual traction control as we know it.
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
An ECU can not tell if you are on ice with no traction management/studs, loose snow, good setup trial or dirt, so building in a table or multiple tables is not plausible.
If there is actually some sort of traction control with a single drive you would need a second speed input, no un driven wheel so options are,radar gun, expensive or GPS, very expensive.
ShootToThrill
I gotta say it's the same as any eps sled. The ecu will know the ground (track speed) from the sensor, where it is on these yamacats I cant tell you. The most it may do is apply boost progressively as track (ground speed) is increased. Such as the eps sleds, the power steering is decreased as the speed increases. It is in no way a form of traction control.
- 6K
- 8K
