In the same vain as this thread, I would like to relate what happened to me this weekend. I just finished the build on my sled, see the link here:
http://www.ty4stroke.com/viewtopic.php?t=114373
Anyways, I took the pictures and then started the sled up and let it run for less than 5 minutes and then drove it back into the garage. As I turned it off, smoke started coming out from under the hood. I lift the hood up and can see flames under the airbox. I yanked the airbox off and the starter relay and wiring around it are on fire. After numerous attempts to smother the fire, I doused it with water. I immediately disconnected the battery and started the inspection.
Well, the wiring harness is toast. Wires were melted throughout. I am in the process of replacing the whole harness and the starter. After wracking my brain for a couple days I finally gave my friend, Rockmeister a call. He confirmed my suspicions that this is another example of the starter staying engaged after starting. The wiring cannot handle the heat overload caused when this happens. So I will be installing the Starter Saver he sells. This is a really serious problem that Yamaha in my opinion should have handled via a recall. This very easily could have resulted in serious injury and/or damage. As this happened in my garage, had I not been able to put the fire out, I could easily have burned my house down, and all the hard work I put into the sled over the last couple months would have been destroyed too. Thankfully I found it quick and limited the damage. I was able to find a used starter and entire wiring harness locally for about $125.00, and hopefully that is all that was damaged The Starter Saver will at least alert me if this ever happens again and I can stop the sled before another episode.
My recommendation is for everyone to get the Starter Saver from Rock. This is only one of the issues you can experience with the Starter, but in my case was as serious as it can get. As Rock told me, others have had it happen when they are out on the trail and then you are screwed by being broke down and stranded. When the starter stays engaged there is no way to tell it is still engaged as there is no drag or noise at all.
