SIMMONS DARTING
YAMMERHAULER
OTTAWA ONTARIO
I installed simmons ski's this year on my RX and now have darting compared to my old doolies that had no darting. I know the simmons are better ski's., but why the sudden darting issue.. It is bad. My limiter straps are backed off to where the ski lift is about 6 inches on hard take off and front spring preload is set to minimun. Any idea's would be a great help.
set the alignment with the weight on the skis... I find it best to have the rider on the machine...
Don't forget shimming them too. Made a heck of a difference in mine!!!
Shimming! As in a small piece of old cut-up track or such glued under the back side of the mounting rubber "foot". Doesn't take much. Maybe a 1" square is about what I used. Helps a lot! There's several threads in the archives here that explain the reasons for it. Suffice to say it works!
I found the Simmons had to be shimmed or premature wear occured at the front of the carbides.
Alignment,alignment,alignment. 0 toe on dual carbide skis. Then shim and be happy!!
