DITCHBANGER
adrenaline junkey
looks like a whole Lotta floatation I think that's one of my next purchases
sawsalesman
What is the difference between the gen 1's and gen 2's. Is it just the width or are there also some other changes?
DITCHBANGER
i think there are some subtle changes..my dad has the gen1's but his sled is tucked away
DITCHBANGER
1-pilot ski-6.2lbs
1 simmons gen2-11.0 lbs
LazyBastard
I think that the added flotation will more than make up for the added weight.
RedRX1
Also a good chance of actually floating that 4stroke front end.
DITCHBANGER
lazy i agree with you..
06vectorgt
Gonna be fun to turn them puppies, better pump-up pre-season!
BA
- Jan 11, 2005
can you give us an overall sled width once you get those puppies installed?
Looks like they will float nicely!
Thanks.
Thanks.
adrenaline junkey
just installed mine the other day i get 48.5 inches outside to outsideBA said:can you give us an overall sled width once you get those puppies installed?
Thanks.
wienerwater
I ran them all last winter on my '03 RX1, 159" X 2 1/4" track and they are well worth it. It does make the front float like it should, especially when going through the trees boondocking a little. Just that little bit of extra float gets you up from a start/stop in the mountains in deep stuff, and able to cruise at a slower pace without diving so much when braking for a turn etc.
Compared to a stock or generation 1 version, they don't compare.
Knowing the creator/inventor/tester personally for many years now, I never have doubted him. With anything out there, there is always someone with negative comments, yet not using a product properly, abuse or for what it's intended design is for doesn't count much in my books. These skis were initially made for the RX1/Apex because of float issues, and I would highly recommend them for any powder/deep snow use. They handle with no issue on the groomed and packed trails and the dual carbides, along with the width, make cornering flawless when rat-racing up the trails. They are a high quality plastic which doesn't impede their strength in all temperature ranges and riding terrain like other manufacturers might ignore, using cheaper materials, that may wear down or shred off on say the odd rock or ice.
This is just my 2 cents (1.8 US cents) PS-make sure you can handle the extra width on older trailers as far as hold down bars for the skis and deck width is all
DITCHBANGER
just an update stock yammie mtn ski is 7.6lbs
