Harvest1121
- Dec 15, 2010
Viper tracks straight but the bars are off center is there a way to straighten bars and not messing with the ski alignment.
rbig18
- Mar 4, 2012
- SR Viper ltx se
How far off? If just a little probably best to set bars straight and use ratchets straps from both ends of bar to running board to hold them straight and adjust skis again. If the bars aren’t held while adjusting skis what you have happens.
Harvest1121
- Dec 15, 2010
Its way off just not a little bit.
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Mine are off as well.i just ride it as it tracks well
BFS
- Jan 26, 2015
- 2016 LTX-LE
Red/White
Bar and ski alignment easier than it may seem. Watch Biker Mikes YouTube video and you will see how easy it is. Straight bars properly toed out skis = a better handling sled. Take the time and fix them you’ll be much happier driving straight and tracking straight.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
If you remove the little plastic skid cover under the nose of your sled you will see a quarter inch diameter hole. Find a screwdriver in your toolbox that fits that diameter snug. Usually a real big Phillips screwdriver fits perfect. Once you insert a screwdriver into the alignment hole it locks bars perfectly straight while you're adjusting the tie rods. Perfectly bars every time.
Harvest1121
- Dec 15, 2010
Is there anything you can adjust the bars without messing with the tie rods?
yamahaguy
Ride SAFE
- Apr 20, 2014
No.
