ski loops for pilot skis
justinator
Maine
2023 Arctic Cat Riot 9000
anyone know if the yamaha ski loops will work with the pilot skis?? I could of sworn I read that they did work but I searched and cant find the post?? Thanks in advance
I also read the same thing here, would like for some one to confirm.
Sounds like the Yamaha handles will bolt right onto the Ski-doo pilots using the same Yamaha hardware.
Kaz
ski loops
the yamaha loop is wider on the longer bolt one, i used the yamaha bolt
I remember reading the same. I think as yamadog said, the Yamaha loop is wider where it bolts to the ski, but it can be used if the excess material on the loop is removed.
That would be nice if that's true. I have the billet handles on mine. I also would like better skis, but don't want to ditch the 170 bucks I spent on the handles.
Yamaha loops
I used the Yamaha loops on pilots, they are wider at fastening points but easy to grind down using side of grinding wheel.
