BombaPolaYama
I need to replace my ski shock and I'm looking for cheaper options such as Royal Dist. I can get the fully extended length = 14.25" but I need the spring off to measure the closed length. Does anyone know that measurement or any tricks for removing the spring w/o a proper tool?
thanks,
Edit: I have the spring removed and it seems like the closed measure is ~ 11.25" (I'm assuming that the closed measurement includes the rubber stop since it is part of the shock assembly). The shocks listed at Royal Distributing with the closest measurement to the VL are gas: 14.375 x 10..25" or 14.25 x 9.5": Would there be an issue with going with a shorter closed measurement?
thanks,
