skid
marc
mississauga,ont
Hey guys , have an 92 v-max4 750 and looking to up-grade the rear skid do you have an ideas on what I can do... thanks..
Given all the improvements the newer sleds offer and the cost it would take to make significant improvement to the old one, wouldn't it be more cost effective and safer to buy a newer sled?
You can upgrade the front springs in your cans also. You can do alot with a proaction long travel rear skid.
Put some adjustable transfer rods on it and sit them LOW. You will be able to lift that heavy dog right off the ground and make it much faster!
check on the 2 stroke side lots of ppl have done this swap in there on older vmaxes.
I swapped in a 97 SX skid into my 92 Vmax-4 and it has worked great. All you need is a stiffer front spring, and 1/4" spacers since the Vmax-4 tunnel is wider. You have to move the rear skid mounting brakets forward about 4" and redrill the other 4 holes.
