nothingman1020
- Dec 8, 2008
I am looking for help from someone who has installed the relocator. I am at the end, step 24 from the instructions. I am trying to figure out a way to loosen the jamb nut at the bottom of the steering relay rod. I can barely get my arm and a wrench down in there, and when I do there is no room to turn the wrench and loosen the nut. Please help me, is there an easier way to do this?
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
nothingman1020 said:I am looking for help from someone who has installed the relocator. I am at the end, step 24 from the instructions. I am trying to figure out a way to loosen the jamb nut at the bottom of the steering relay rod. I can barely get my arm and a wrench down in there, and when I do there is no room to turn the wrench and loosen the nut. Please help me, is there an easier way to do this?
I think I took the voltage regulator out of the way. If you take of the 2 8mm bolts you can set it down on the bottom of the subframe and have some more hand room.
Feel free to give me a call if you are still having problems with the drag link.
Scott
952.465.7399
Scott
952.465.7399
I remember having the same issue when I installed my relocator, but I was able to get the nuts loosened with a normal "key" (dont know the english word ).
However I also remebered that I missed my crowfoot sockets which would have been perfect for loosening those nuts. (had them in another garage).
Heres how a crowfoot look:
http://www.sears.ca/usa-product/allen-1 ... S-40834210
You attach it to a "lengthener" that you attach to a wrench. Sorry for the bad english.. .
Also, one of the nuts are links! Cant remember which of them was what..
Blue Hornet
I lost a snap-on crowsfoot to the bottom of my sled trying to loosen the nut. Hey, if anybody notices one on the trail let me know!
