sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
PoliticalMachine said:sorenson1610 said:Anybody try the weights yet?
Politicalmachine what hole are you running your swaybar mount in?
I just picked up some weights today they look like they will work great. I have the sway bar mounts in the middle hole.
Where you get them from? Post up some pictures when you have the installed
Oh ok I started off with mine there too but i moved to the front hole and noticed a huge difference with controling ski lift. Give it a try......i liked it much better
PoliticalMachine
- Oct 20, 2010
- Valparaiso, IN
- Yamaha
I got the weights at discount tire. I asked for a strip and they gave it to me for free. There is 10 or more weights on 1 strip. You just break off what you need. It looks like I'm going to have to double the weights up to get it where I need it. I will post some pictures tomorrow.
PoliticalMachine
- Oct 20, 2010
- Valparaiso, IN
- Yamaha
As for the sway bar, I haven't been able to ride this year at all. I will definitely try the first hole. I still cannot believe how bad this winter is. I thought surely this was gonna be a great winter, there is no way it could be worse than last year (wrong!). Might have to make the drive out west.
PoliticalMachine
- Oct 20, 2010
- Valparaiso, IN
- Yamaha
PoliticalMachine
- Oct 20, 2010
- Valparaiso, IN
- Yamaha
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Yeah I hear ya on the brutal winter.....as its been 40 degrees here for the last 3 days. Hope the UP snow machine starts kicking in here soon!
So how's the weights work, is just the one weight enough? Looks good
PoliticalMachine
- Oct 20, 2010
- Valparaiso, IN
- Yamaha
I ended up adding another weight on top. Now I just need snow.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Sounds good, need to get some tire weights now
snodogger
- Nov 15, 2013
Either your tie rods are backwards or mine are. Mine don`t hit. the instructions wer very clear where the short end of the bend goes for clearance. Not the greatest instructions but that part was clear.
judger101
I don't know, mine where hitting last year as well so I have also put on stick on weights and it works great.
