Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
You had lights? Mine was a plate with a ball mounted on it I bolted to the back of a 1977 Plymouth Volare. We hooked my buddys dads 4 place to it and headed to the U.P. with a couple of ski doo blizzards. We reasoned that since we would be driving during the day we could get bye without lights.BTW
My first trip up north, in 1985, i put a hitch on a 1978 Honda Civic with basically a street legal yard trailer.
I tapped into the brake lights 10 minutes before we left.
I had to go down hills at 80 to get up the other side.
Topped off the oil every hour.
I've been hooked ever since!
It's where the O in OCD started as in OH MY GOD!
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
My god how fun it was to be young & naive!
Not a care in the world
Mine was a 1981 Blizzard 5500 also
I was going to remove my aluminum deck off my old sled trailer , take off my old bed 1977 Ford 4x4 and mount deck to frame with a couple of braces up under for extra support but never did .. . But then I wasn’t ever going to haul any sleds , no where to mount ramp anywhere anyway ..just to haul whatever on it . Bed is still on it
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
I could do it with my F150, wouldn't want to, but It would be right at the "legal" weight limit (1650# payload) with just me, no passengers. A Steel deck like that, with plywood is probably around 500#. Toss on 2 600#+ sleds (full of fluids) and your over 1700# already. Most 1/2 ton trucks come with Squishy P-metric tires also which wouldn't play well with a high center load like a loaded sled deck, I upgraded to Load C rated tires on my truck and it help load/towing stability a lot.
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
Could you - Probably.
Should you - Probably not.
What year pickup or do you know the GVWR?
Odds are you will need to add extra leaves to the springs, air bags and/or timbren kit for the weight. Do it all the time at work as modern trucks have issues hauling 1 sled/atv in the box most times. I would go the timbren kit route as they help a lot with the top sway. Have had the kit on 3 of my last 4 trucks. Tried air bags on last one and was more maintenance than I wanted.
Vmax
- Mar 20, 2018
- Lasalle
- 2023 ZR 6000
Install a set of Timbren on your 1/2 ton, it turns it into a 3/4 ton for a few hundred bucks. I put them on my 1/2 ton years ago before I bought a truck camper when my son was moto cross racing......they worked great
Confused
- Oct 12, 2008
- Mound, MN
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
Adding suspension parts does not increase your trucks GVWR or turn it into a 3/4 ton. It may appear to not be crushing your truck by keeping it level but the axle, brakes, frame, etc are still 1/2 ton components.
