thinking of upgrading from my old chain hoist to a lift of some sort. what are guys using and what is the best bang for my buck? I have a 05 venture and 10 vector ltx so I guess 800ish pounds is my weight.
kidastra
look like a nice unit.. so what "cant" you do using this style lift?
kyleg
Jsjacks.com expensive but pretty nice. I also use the princess auto one.
thanks.. what are my limitations with this style? can you yank a skid out for example?
dexter said:look like a nice unit.. so what "cant" you do using this style lift?
Its a good lift. You can't really remove the skid while using the lift.
Chain hoist or winch from the rear bumper works the best for skid work.
thanks stiener.. what is the advantage to these then? what is their selling point?
If you have to do any kind of motor work ,clutch maintenance, Hell changing wear bars make life easier so you dont have to bend over. I made mine and love it.
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
http://www.klsupply.com/SHOPLIFTEQUIPME ... fault.aspx
K&L tool sled lift! A little bit on the $$ side but just an amazing addition to the shop!
kidastra
never tried removing the skid, hoist works much better
any work on the front end is what I use mine for, except oil changed, seems like the drain cover is right where the front support is, also good to store the sled off season, gets all the weight off the suspension,
I originally bought the same looking lift from royal distributing. I did not trust that one at all, looks the same in pictures but the gauge of the steel isn't close to the one from princess.
CaptCaper
- Jan 1, 2007
- Northern N.H.
I bought this one and it works well. Customer service has been good too with them.
I bought the long track version. It has arms that lift up. http://www.eazymovecarts.com/upez/index.html
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
kidastra said:dexter said:look like a nice unit.. so what "cant" you do using this style lift?
Exact same reasons what I use mine for, plus I use it to help with the snow/water removal after a ride.
I also purchased the PA as I founf the same with the Royal ones.
If I owned an Elan, the Royal one would suffice, but anything larger imo, your just taking a chance on.
Keep an eye out for sales, I purchased my PA for $168 then it went further on sale and I got it for $119.
sgauthier
i've got 2 from princess auto for $169 each. i use one for my XTX and the other for my srx/vmax. like others mentioned makes working on the sled sooo much easier on the old back. FYI. i used a couple of hockey pucks for cushion against the running boards(also levels it) and shaved the side facing the track to make it easier to pull it in or out when using it. great price and they even come with the wheels where others charge you extra.
kidastra
I'm using mine today to do my bushings
