Highmark
Does anyone know if the Sledpro clutch alignment tool for the SX/SRX will work on the Apex? I know they use the same belt but I'm not sure on the center to center distance or the offset.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
If they use the same belt than your center distance must be the same,so yesHighmark said:Does anyone know if the Sledpro clutch alignment tool for the SX/SRX will work on the Apex? I know they use the same belt but I'm not sure on the center to center distance or the offset.
Highmark
Center to center distance is not the only factor in belt length. Pulley diameters must be calculated as well. I wasn't sure if Yamaha did any changes to the Primary and Seconday clutch diameters. I want to know about the offset as well because that can be measured by the SledPro tool as well.
ltemple
Highmark, did you ever figure out the Sled Pro tool, I own one and am tring it out, I thought you might be able give me some pointers on the alignment. Center to Center is spot on but the front pin on the tool is about 1/32 behind the primary and the other 2 are perfectly aligned. I tried turning in and out the adjusters but nothing seems to make any movement.
