Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I noticed wear on my slider runners and I was wondering how that could happen. These are the plastic pieces on the front of the skid, prior to the Hyfax.
The wear seemed excessive and unusual, could this be caused by a loose track?
yammi
Just replaced mine @ about 5,500 miles. I think I let the hyfax run too low. If they're the ones I think, they're about $25 a piece. Good luck!
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
Loose track and, or do you have your limiter straps out all the way, this will cause the track to hit these bumbers. had the same problem on a 2000 SXR.
Bob Miller
- Apr 19, 2003
- New Milford CT
yamahinn03 said:Loose track and, or do you have your limiter straps out all the way, this will cause the track to hit these bumbers. had the same problem on a 2000 SXR.
What do you reccomend for the limiter strap adjustment?
Len Todd
Loose track? How much droop do you have in the track? Feel or hear any ratcheting?
There is a spec for the strap adjustment. If I recall correclty there is quite an acceptable range. However, I left my Service Manual at the cabin. Maybe someone else has one handy. If you look and there is no tension on the straps, then they are probably too loose.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
12 Nytro XTX (mine)
09Apex GT (?)
With the sled sitting on the garage floor or any flat surface look up front and you will see if it is to close, thats how I found it on the wifes sled and it also vibrated some at higher speeds. When the track comes around the rails the windows hit the bumpers, if so suck them back up.
Bob Miller
- Apr 19, 2003
- New Milford CT
Thanks Guys
