SLP HYPERFAX ANYONE TRIED THEM?
milkman
novascotia
Thinkin of ordering slp hyper fax because I can only get one season on regular hyfax.I have installed slp hyfax anti wear pads and it didn't seem to help so do you think I should go for the hyper fax?
Thanks Milkman
I have heard goos and bad about them. They do take 3 or 4 hundred more degrees to melt them. But I also know form a friend that had them on a srx, they will get alot hotter before you notice a problem. What he said it ruins the track, it over heats the the track bars and crystalizes them, and then track failure.
I've run 3 sets of them over the years. Really like them. I actually think they can make a sled faster. Last a very long time if heat is the issue. But if you got dirty snow with abrasives (snand and snirt) they can get eaten up fairly quick too.
Never ever caused damage to track or clips. With 3rd window closed, they highly recomment using SLP wear pads.
Not to disrespect other opinions in the slightest (I dont play that game), but in the post above, I am 99.999% sure that teflon hyfax could not possibly ruin a track. Has to be some other issue.
