tnc110
- Jan 5, 2015
- Sidewinder BTX SE, SRXs
Why can I only find 3 threads about slydog skis on a viper (short threads at that)
So whats the scoop, I've read a ton about how great the Curves are,but not much on the Slydogs either way. Anyone try both?
I've got a 15 ltx se. I ride 95% trails. I don't want a ski that requires a bunch of steering effort.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Cannot comment on the Curves. But the SlyDogs, ran the 8" on my turbo Cat for the last 4 seasons. Its like putting snowshoes on the front , NO MORE submarineing . Waiting for the spring storms in Munising to try them out on the new LTX. They work quite well as a trail ski also, I think.
Threeman03
- Nov 1, 2015
- Flushing,mi
- 2016 Yamaha sr viper ltx LE
I have a new set of white Curve XS skis with new 4 inch carbides on them and a brand new set of 6 inch still in the pack for sale for $400 if interestedWhy can I only find 3 threads about slydog skis on a viper (short threads at that)
with stainless steel hardware
tnc110
- Jan 5, 2015
why are you not using them on your viper?
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Probably the reason you're not seeing very many reviews for Slydogs is becasue is becasue most guys on TY are trail riders. Most of the guys that buy Slydogs use them for off-trail use not trail. I can think of 6 guys I ride with that have wide Slydogs and use them for back country riding and love them. Steering effort on the 8 inch wide is a non issue, my arms are never tired after a ride.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
I'll chime in as well since I run 7" dogs in a mix of both trail and off trail on my LTX. Slydogs are an aggressive single keel ski, and as such, are prone to some darting in comparison to tuners on trail. Off trail, no issues with darting. On trail they turn as well as or better than tuners, even with the stock slydog 4" carbide. Even in loose snow, they turn. Steering effort is a little higher due to the aggressive keel, but when moving, you don't notice it. It's only a problem when you are stopped in packed snow. After riding both, I'll stick with the dogs and will tolerate the dart for the benefits they provide off trail, and their predictability on trail. I may try slimjims next year to see if it improves the dart. Slimjims for Curves will bolt right on.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
I run the 7" dogs on my XTX, one buddy runs the trail version on his LTX, and Hellhounds on a 137 ZR. They turn great on the trail and in my experience they don't dart at all. If anything they push a little, but thats on my XTX riding real hard. I would recommend them to anybody for sure! A very light ski and you can pick from a variety of color combos.
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
I had the 7" Powder hounds on my 14 XTX and they were O.K. but did tend to push some in the corners.......really good off trail...........that was with std 6" shaper bars.......switched to Curve XS with Slim Jim Doolies and never looked back........rails around corners.......and still decent flotation off-trail......
Never thought to try the Doolies on the Slydogs........same bolt pattern............
farmerschiferl
- Dec 28, 2010
- Hewitt,WI 54441
- 2017 Yamaha Sidewinder BTX-LE
- Hewitt, WI
I run the 8" slydogs on my XTX with 8inch bergstrom triple points and have almost no dart on trail. They are an aggressive ski but really cant tell one you get going, very predictable on trail with plenty of flotation off trail. I also just could see spending the big bucks for the curves.
tapex_07
- Feb 15, 2009
Buddah, do you think its because of the Slim Jim Doolies vs the std 6" carbides?? Or actually the SKI making the difference?
buddah
- Apr 14, 2003
- Wetmore, MI
Hard to say......wish I had had the presence of mind to try the bars on the Powderhounds while I still had them......but I didn't so..........I do know the skis seemed pretty comparable off-trail at least to me...........
Threeman03
- Nov 1, 2015
- Flushing,mi
I did for 1 day. I preferred the tuner 3's. im 100% UP trail rider. was to agrresive for mewhy are you not using them on your viper?
stranger
- Jan 31, 2022
- indiana
- 03' RX1
13' xf 1100 turbo
24' catalyst zr600
25' catalyst zr858
Would you think "rails around corners" is due to curves or doolies?I had the 7" Powder hounds on my 14 XTX and they were O.K. but did tend to push some in the corners.......really good off trail...........that was with std 6" shaper bars.......switched to Curve XS with Slim Jim Doolies and never looked back........rails around corners.......and still decent flotation off-trail......
- 10K
