dylanjen9
I know it is not a 4 stroke but does anyone know were I can get a track for a sno sport that does not cost $600. I guess the sno scoot track is smaller than the sport. Does anyone make them or is there a different track that I can get to fit?
couch
I believe that they are no longer available .... scoot will fit but you have to shorten up the rails slightly....
best option is to stretch the Sport out to a 121" - yes the little 125 cc can handle it ... have long tracked a couple and the difference is night and day in regards of ability to go off trail and still run at 50+ kph on trail.
Theres lots of build info and picks on the snowiest forum .... you will need a set of drivers, a set of donor rails and a used track cut down to 12.5" wide ... 121 x 1.25" lug (or less) track with same pitch as the drivers ...
AD Bovin also had some snow bike tracks with a similar type pitch but would need to have windows opened and clipped. Timbersled bike kit also has a factory 121" x 12.5" track that you could use ....
aftermarket drivers to fit the original bravos (square shaft) to let them run the newer 2.52" pitch tracks are what you want. Used set of rails from an ovation , citation, tundra, etc. will work - you will need to do some basic mod work to make it all fit but other than that you can use the stock suspension setup ...
Other additions - plastic skis (a must do), phaser / exciter fairing (easy fit), hand warmers, tunnel mod (looks better) Skinz type air boards (simple mod if you have access to a wielder. riser block.
http://www.youtube.com/watch?v=2KIkbboZXn4
Yamaha should really reintroduced this type of sled - was waaaaaayyyyy ahead of its time ... rider forward, decent suspension, strong frame, easy to work on / repair ..... would be a hoot with 1/2 a phazer motor (say 30 to 35 hp) with a detuned key like BRP ACE for new / young riders.
Broue
- Feb 28, 2015
- FX Nytro XTX 2009,
Factory race front end
Star suspension relocation kit and revalve
Ski Doo #503192064 center spring
135 mm idler wheels
Oilite bushings
Grizz steering relocator
Tuner ski : 6 ''carbides,
WRP seat
Vector gauge
Custom Taillight
LinQ tank
Sno Sport 1990
Ski Doo Tundra R 1998
I changed the track on my son s sno sport.
Pretty simple:
Yamaha Bravo driver (Kimpex)
Camoplast track (ATV kit) : I not sure but I think the track is no longer available
Drill hole and clip it
I ve got the right dimension 12 inches x 90 inches
Second option
Camoplast track (ATV kit) : I not sur but I think the track is no longer available
Rail extension
Driver ?
third option :
Yamaha bravo rail for 108 in track
Yamaha bravo driver
Ad Boivin explorer kit track
Drill and clip
Pretty simple:
Second option
Rail extension
Driver ?
third option :
Yamaha bravo driver
Drill and clip
