mdkuni
Anyone else have their snow flap bracket cracking? I went through a couple on my 06 and now one on my 08. Really getting tired of replacing them, not sure how much longer my flap will last after drilling out the rivets so many times.
I do not run studs and I am not backing over the flap.
yamaslob
Same boat with my 06, i finally gave up on the rivets and replaced them with nuts and bolts!
-James
-James
tender33
- Nov 13, 2007
- Peterborough,On
- 2020 Sidewinder LTX SE, Blue/ Orange
Same on my 08 apex. Just left the old one on.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Same on mine I moved the bracket up higher so I can drill new holes and re use it. Yeah this year went to bolts on the snow flap! Little 1/4" SS bolts.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
mine is cracked too.
i plan to remove it this summer and fab something heavier/sturdier to mount the flap.
100 bucks for a bracket that is going to break again is a little steep
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Made this for Dad's Vector, similar one for Uncle's. 1/8" aluminum. I didn't bend the ends on Uncle's (not shown). Both appear to be working, my biggest concern is cracking the muffler support, it's pricey and is cast....
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
i did like chief did - my sons 06 nytro was breaking the rear mount over and over - i got a little thicker piece of aluminum and just fabbed one out of thicker stock - i put a little more pitch on it so the flap stuck out further and away from the track to avoid that pesky running over it in reverse.
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
I installed the bracket from either the 08 or 2010 model. One of the two is half the price of the other. They are designed better than the 06 model. Also, be sure to order the Yamaha rivets too!!
mdkuni
Crewchief47 said:Made this for Dad's Vector, similar one for Uncle's. 1/8" aluminum. I didn't bend the ends on Uncle's (not shown). Both appear to be working, my biggest concern is cracking the muffler support, it's pricey and is cast....
I have the same concern. I figure the bracket is a failure point. There is always that fear of if you make something stronger something else has to give.
I wonder if increasing the amount of rivets or adding some washers to the rivets would help spread the load?
mdkuni
87gtNOS said:I installed the bracket from either the 08 or 2010 model. One of the two is half the price of the other. They are designed better than the 06 model. Also, be sure to order the Yamaha rivets too!!
06 bracket is $136.71
07-10 bracket is $44.01
87gtNOS
- Nov 30, 2005
- Toronto
mdkuni said:87gtNOS said:I installed the bracket from either the 08 or 2010 model. One of the two is half the price of the other. They are designed better than the 06 model. Also, be sure to order the Yamaha rivets too!!
Ah yes, thanks! It was about 5 months ago when I changed mine, that is why I couldn't remember exactly!!
Also, IMO....extra rivets will only cause more weak points.
Crewchief47
- Jan 16, 2006
