snow flap
zook
NH
What are you guys doing about the snow flap getting sucked under the track ?? It happens even more when you're going fast across a lake.
Add a couple of nylon straps to the flap
I had this problem last year, went thru like 6 flaps, long and short. I installed a "W" shaped bracket for like 5 bucks and it fixed everything. here is the link;
http://www.hiperf.com/
Thanx Guys for the help
Strapped Flap
Here is a couple of pics also.
Put on a shorter flap like this one: 8CR-77595-10-BK ( BK is for black)
I believe you can get them in different colors.
I have found that even a shorter flap can get sucked in on occasion. Not to mention the shower you will leave people covered in behind you. The W bracket looks to be a pretty decent solution also.
I tried the W bracket and it didn't work very well and I found it caused a huge ice buildup on the flap. Just put a shorter flap on and it works great and looks much better.
I think I might try and bend it back and then cut it alittle but. Thanx again
Maybe I'm not going fast enough. :o| I haven't encountered this problem. :Rockon:
I just keep doing monster wheelies, and big jumps, and somehow the flap never gets close to getting sucked under.
:D
