Snow trackers
Nytro08
Albany ,ny
2008 Yamaha nytro
Hey guys n gals new to the site and nytro world , I have a new to me 08 nytro standard model , went out for my 1st ride and is all around is better ride then my firecat. My only dislike is it scares the hell out of me when aggressive trail riding I dont know if it's going to turn or not,I have gen 1 yamaha tuner skis and have been doing alot of research on different ski and wear bars and theres so many different opinions. I want to spend my money once on change ups . I'm thinking of doing a pair of mtx skis with snow trackers does anyone run this set up and happy with them? I want know the sled is going go where and when I want it and not wonder what tree it will be that I'm going to end up kissing lol
Hands down the best thing you can do to a nytro is split rail skis but they are not cheap, I ran them on my 2013 nytro.
Second best thing is snow trackers on Yamaha single keel skis, my buddy has a nytro with ST on Yamaha single keel skis and it handles great, ST will eliminate all the twitchyness you are experiencing, zero darting and goes where to steer it. mtx skis are single keel so they will work great,
Ditch the tuner skis as they will push in the corners, as you start to turn the snow builds up between the keels which lifts the skis off the trail and cause the push, the split rail skis are similar to the tuner but the centre of the ski is cut out causing the snow to flow through between the keels and keeps the sled glued to the trail in all conditions.
mtx skis and snowtrackers are an awesome set up (make sure to adjust to zero toe in for this set up...) my.02
Do you run this set up ? I'm going to pick up mtx skis and trackers after work today
yes i run this set up, and run stock skis with ski skins over top with snow trackers on wife's vector (7 1/2") heavier set up (its 4 stroke...doesn't make a difference) aand saves money on new hardware for mounting skis
Did you make any suspension changes before or after installing them
only change was 0"/mm toe in as per the kit....i have done alot of suspension stuff to it over the years, it is pretty spot on now. i have a couple of things i might do this summer though
Last question , converting to the mtx ski how did u fill the gap between the spindle /ski /bolt, I keep trying to up load a pic but says file to large , theres no gap with the tunner skis
there are spacers between the spindles and skis, as the openings are pretty huge. when doing this setup i spent almost on hardware as it cost for the take off skis. the wide saddle openind does allow for quite a bit of adjustment in width as a result. i can take some pictures in the morning for you if you want. dont worry about questions, thats what this place is all about.
cheers
cheers
If you could that would be awesome I have mtx spacers and 1 spacer from the other skis and still have some gap, a picture to use as reference will def help
PM me your info or i will email or text you pics, i haven't been here for quite a while and having a hard time loading pics
