jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
just purchased a used set of snow trackers for my wife's 08 Nytro. Does anyone know the details of installing. Do you need to drill a hole in the ski close to the front for the front part of the tracker?
RobWarrior
- Oct 4, 2008
- Western Ma
- 09 FX NYTRO RTX
I installed them on my 07 but if your using the stock skis yes you have to drill a hole...think it's a 1/2" hole. They work awesome just watch RR crossings, make sure you cross at 90 degree angle of they can grab the track.just purchased a used set of snow trackers for my wife's 08 Nytro. Does anyone know the details of installing. Do you need to drill a hole in the ski close to the front for the front part of the tracker?
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Thanks. Thought I had the wrong ones as I figured they went through where the stock carbides go through. Is there a dimension on where to drill? And do you drill on an angle?
RobWarrior
- Oct 4, 2008
- Western Ma
- 09 FX NYTRO RTX
should have been instructions with them, it's been a while since I installed them don't remember.
read this:
http://www.snowtracker.com/getattac...ntively-befor-installation-agressive.pdf.aspx
read this:
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
I will check and let you know tomorrow..... I will measure my spare skis in the morning.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Drill 1/2 " hole straight through the ski
60 degree angle the hole after it is drilled.
Hole should be either 5 1/4 "or 6 1/8 inches forward from 1st runner hole depending on which Trackers you have.
Put the bolts of tracker carbide in the ski holes & measure to see which measurement is correct.
You will love them.
You will love them.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Perfect thanks for the help.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Riceburner
- Apr 14, 2003
- N.B. Canada eh
I would still do this: Put the bolts of tracker carbide in the ski holes & measure to see where 1/2 hole should be drilled.
These instructions are different drom those they give out now for where to measure from.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Awesome really appreciate it.
