dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
Are you guys mounting the snowflap to the tunnel without any reinforcements? If you hit the snow flab the aluminum flexes where the flap mounts to. Just wondering if anyone has had a problem with this?
The Hartman kit is great quality and excellent customer service Tom even called me back on Sunday with some questions I had!!
xrrider
Mine is a Tracks USA extension and does the same thing. I was a little concerned too but ran it last season with no problem, even stuck a few times with the snow flap pointing straight up.
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
dremmick said:Are you guys mounting the snowflap to the tunnel without any reinforcements? If you hit the snow flab the aluminum flexes where the flap mounts to. Just wondering if anyone has had a problem with this?
Yeah I broke the bottom of mine. I was using the flap mount and to fix it I moved the flap further up on the extension. That was my 136" extension, now with my 144" from tracks USA it uses the stock tail piece so it will likely be better.
This isn't really a problem for trail riders It's when you are in deep snow and that flap gets bent straight back. My rivets broke thru in the mountains.
If you want I can take a pic of what mine ended up looking like
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
Yeah a pic would be great!
ultra_rob
I have never been much of a flap guy so I mounted a piece of aluminum "L" extrusion to reinforce the back. Just some stuff I picked up from a bin at NAPA, I used the snow flap holes and put rivets in between here are some photos of my install. I don't know if you would need it or not if you had the factory flap on, probably not as if it was he would have included it.
http://i977.photobucket.com/albums/ae25 ... 1ff253.jpg
http://i977.photobucket.com/albums/ae25 ... 894b86.jpg
thedoityourselfguy
- Dec 2, 2013
I made my bumper kit as easy and cheap as possible.......used the stock tunnel extension piece and wrapped in vinyl although I can get an extension made up out of 1/8" aluminum sheet. Just didn't this time cause my metal guy broke some ribs so he is out for a little while.
