Snowtrackers and limiter strap
snowdust
Northern Illinois
Sidewinder
For those running snowtrackers... Was it necessary to drop the limiter strap one notch from stock? How about weight transfer... Can you get away with running a little more and still rail in the corners?
Been running this set up for the past 2 yrs and can still rail with the best of them.
snowtracker extremes
limiter strap - up one from stock
transfer rod - set to Max
front springs - zero preset
How is your steering effort?
Snow Trackers are just awesome. Steering effort is great. Darting is gone and they steer thru the corner rather than push. You'll be able to drive thru the corners faster with much more confidence. Expensive but worth it. I've spent an extreme amount of money on carbides and these are the real deal.
No need to change the limiter.
