Northernshift
- Nov 27, 2014
- 2013 Vector LTX
I put a set of semi aggressive snowtrackers on my 2020 Viper ltx gt. I followed the instructions and reduced my front suspension to about 1/4 preload (loose), the front track shock is at stock setting and the rear torsion springs at 2nd cam adjustment. All the QS 3's are at 1. The sled handles really good, no darting, minimal push in the corners. The only problem is with the front preload at 1/4, the A arms are now sagging downwards at a slight V and I've only got about 2" of shock travel. The front suspension feels rough on bumpy trails. If I increase the front preload to 1/2 of the threads it solves the sagging and shock travel but the sled starts darting. I'm at 190 lbs ride weight. Any advice?
apexhank
- Mar 5, 2011
- HUDSON FALLS AND BIG MOOSE LAKE, NY
- 2021 SIDEWINDER LTX GT (soon)!
2019 SIDEWNDER LTX DX 6000 miles
2018 VIPER LTX DX 2200 miles
2014 VIPER LTX DX 8000 + miles
2014 BENNINGTON 22 ft. PONTOON BOAT/ 90 HP Yamaha
I’m running a 19 SIDEWINDER LTX DX, with CAT skies. Couldn’t get the tuners dialed in. I also have a 14 and an 18 VIPER LTX DX with cat skies, that was how I got them figured out. Tuners are good for going in a straight line. Three sleds with Cat skies and snow trackers, without any problems.
Hank
Hank
Northernshift
- Nov 27, 2014
- 2013 Vector LTX
Are the Cat skis dual keel? Are the snowtrackers for these skis similar to the ones on the Tuner 3.I’m running a 19 SIDEWINDER LTX DX, with CAT skies. Couldn’t get the tuners dialed in. I also have a 14 and an 18 VIPER LTX DX with cat skies, that was how I got them figured out. Tuners are good for going in a straight line. Three sleds with Cat skies and snow trackers, without any problems.
Hank
apexhank
- Mar 5, 2011
Skies are single kiel, not sure if trackers will fit. Go to website : OKTAIN.COM. You can contact the owner of SNOWTRACKERS that designed the SNOWTRACKERS for all sleds. Real nice guy and is more than willing to advise you.
Hank
Hank
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
The tuner trackers are dual carbide with 2 L brackets, 1 L bracket goes under each carbide, trackers on the tuner ski still keeps the gap between the keels, the cat ski tracker is single carbide with one u shaped bracket just like every other snow tracker.Are the Cat skis dual keel? Are the snowtrackers for these skis similar to the ones on the Tuner 3.
Northernshift
- Nov 27, 2014
- 2013 Vector LTX
Looks like Oktain doesn't exist anymore from my web searches.Skies are single kiel, not sure if trackers will fit. Go to website : OKTAIN.COM. You can contact the owner of SNOWTRACKERS that designed the SNOWTRACKERS for all sleds. Real nice guy and is more than willing to advise you.
Hank
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Crank up your center shock spring a whole bunch. Gradually add front ski pressure until you are happy with it. I have a stiffer front skid spring in mine.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Darting really isn’t an issue for me
pdiddy
- Oct 12, 2004
- Southern Maine
- '18 Vector 129", '18 Indy 600 SP
It should be almost impossible to get snow trackers to dart. Make sure your toe adjustment in near zero.
Northernshift
- Nov 27, 2014
- 2013 Vector LTX
My skis were 1/2" toed out, 0 toe now. I find that the more ski pressure I put, the more it darts. It doesn't dart at all now but my ski pressure is down to 25%.It should be almost impossible to get snow trackers to dart. Make sure your toe adjustment in near zero.
