Snowtracker's (Loading into a trailer)
Doo 2 Blue
Moncton, NB. Canada
Looking for info on what to expect with the snowtracker's when you load the sled into a trailer.
Concered about what happens when they hit the plywood floor.
Thanks for the info
The carbide runner sits proud of the steel channel (rectifier) so the steel channel should not come into contact with the floor. That said, the carbide itself is very narrow and may slice up a raw plywood floor. Best to have plastic ski-tracks if you can IMO.
If you are not studded they can stop you dead. Also cut the guides clean through down to plywood on my Toy Carrier. Not complaining, this is my second set and love them.
Never had a problem with them on my nytro Easy loading and barely marked the plywood. I had the semi aggressive ones.
