Koenig
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
any chance someone has the direction that come with the new carbides?
Koenig
not sure of your question... if post #16 doesn't explain the setup then contact Snowtrackers.... Google is your friend!
Contact us
409 rue des Pins
St-Elzéar, Quebec, Canada G0S 2J2
Phone: 418-386-5903
Fax: 418-386-1856
Cell: 418-389-5662
We are open Monday to Friday from 8:00 a.m. to noon and from 1:00 p.m. to 5:00 p.m.
Email: info@snowtracker.com
Contact us in the USA
STRIKING DISTANCE SALES & ASSOCIATES, LLC
1-855-387-8757
usa@snowtracker.com
https://strikingdistancesales.com/
Visit us
COPYRIGHT © 2020 SCM-GL INC . A REALIZATION OF PANICAN INC.
t sure I understand your question, but, if the instructions in post #16 aren't enough.... well give snowtrackers a call!
Contact us
409 rue des Pins
Phone: 418-386-5903
Fax: 418-386-1856
Cell: 418-389-5662
1-855-387-8757
usa@snowtracker.com
Visit us
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
I run Snowtrackers on all my sleds . Align the skis straight not toed out . Front shocks. loosen the springs until they move up and down just a little. Then tight just enough so they don’t flop around . Your A arms should be level not angled up . Adjust the transfer rod in rear suspension to minimum transfer. If you need help with the transfer rod do a Google search on it . This will make your sled push less and Rail the corners .
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
Should I do anything with the rear limiter strap
DGZRT
- Feb 23, 2006
On one of my sleds I pulled it up one hole tighter . But my other two are In the stock holes . Google: 2010 RS Vector suspension setup . You will see a post on TY. Look about 3 post down and Catman give tons of details and measurements. I would post a link but I’m on my phone.
A few questions.
Snow conditions. Loose or hard pack?
Front spring preload settings?
Limiter strap setting?
Transfer rod setting?
Rear spring sag or preload setting?
How did the sled handle before changing to Snowtrackers?
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
This was my very first ride on the sled as I purchased it end of last year so I have nothing to compare to. I checked my front shock spring tension and they pretty good. I adjust to toe in and out of the skis and tighten the rear limiter strap one hole. I will see how it goes next time I take it out for a ride
Snow conditions on Friday when I road was poor at best, corners were loose pack.
From pic posted front shock springs are too tight.
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
When I raised up the front of the sled there was very little pressure on the springs and I was able to spin the springs around by had very easy
rkkoeb
- Aug 30, 2019
- Green Bay
- None right now
That looks better for front height.
That alone would make you push in the corners.
What sled did you have before this one?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
I had trackers on both my 07 gt and 11 se and they worked wonders.
The mono is a bit different as it only has one shock in the rear, get the front springs as loose as possible like others have said and also on mine I always adjust the limiter straps to there longest setting, shortening the straps will add weight to the front which you don’t want with snow trackers.
BryKlu
- Nov 1, 2017
- Presque Isle, Wisconsin
- 2010 Vector LTX GT
So a buddy of mine installed a set of snowtracker skags on my 09 apex. I took it for a ride today and it handle really bad. To me it looks like they are installed to far forward on the ski. What are your thoughts?
They are too far forward.
