Soft spring
xtx
Ontario
I have a stock 2014 xtx , has anyone tried just the soft spring from Barn of parts ? If so what were the results ? Thanks
We tested in several apex's with great results. Have had several customers report back with satisfaction after installing in their apex.
The spring engages when clutch rpm is 25-2800. An apex or rx-1 will tach higher than that at engagement because the crank is spinning faster than pto due to the gear reduction. Many people forget about this
was wondering if u knew difference in rpm from clutch to engine or tach?
I use one and I love it! Engages around 2800 RPM. It’s nice to use the torque of the motor and not blow the track lose. I recommend it.
