DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Are there softer torsion springs than what come on the sidewinders? I've searched but most are looking for stiffer.
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
Not sure if cat or yami have anything? But try Hygear I believe they do.Are there softer torsion springs than what come on the sidewinders? I've searched but most are looking for stiffer.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Barn of parts makes a torsion spring relocation kit that softens the stock springs. It works very well. I have a like new used one if your interested. I ended up going back to stock, I found it a little to soft at hi speed but I’ve put on a few pounds over the last few years.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Are you looking for lowered ride height? Srx rear torsions will do that.
DMCTurbo
- Nov 12, 2005
I'm looking for a set of softer torsions so that when I get on the sled it squats down.Are you looking for lowered ride height? Srx rear torsions will do that.
justinator
- Mar 25, 2007
- Maine
Hygear has a bunch of different ones available for different weights. If you send them an email and tell them what your looking for im sure they could set you up. It says they have softer and stiffer then factory. There are usually good about replying to emails although they may be closed till monday due to thanksgiving.
DMCTurbo
- Nov 12, 2005
I'll check them out. Thanks.Hygear has a bunch of different ones available for different weights. If you send them an email and tell them what your looking for im sure they could set you up. It says they have softer and stiffer then factory. There are usually good about replying to emails although they may be closed till monday due to thanksgiving.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Stock SW is 16,5 and that’s pretty soft. Lower than that and you will bottom out easily. Personally i ride the 18,5 from 2015 viper and it’s a HUGE difference on ride quality.... Have you consider bending the one you have a little?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
What is the rider/cargo weight?
DMCTurbo
- Nov 12, 2005
The stock ones are great for trail riding. I'm looking for a softer set.
SRX or Thundercat springs
