gunnerthesnowman
bottlerocket said:Is OSPs stand alone water proof?
I dont know about the Big Stuff 3 that he uses on the outlaw sleds but the standalone used on the King Of the Trail kits are water proof
http://www.youtube.com/watch?v=-_sPvMjWvPY
MRFUSION
- May 19, 2008
- Peace River Alberta
- 2011 Custom Built Nypex
2008 Custom Union Bay 980 MM Chassis
Can you fire aux injectors with the BD box on the Apex? I know you can on the Nytro BD box.
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
- Yamaha Viper and Yamaha Nypex
I sure hope so
According to Scott it can.
MRFUSION
- May 19, 2008
I know it can on the Nytro BD box, thats how he does it on his kit but didnt think it was an option on the Apex box. Will have to check into this. Thanx Shad
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
Well, if it can't i have to hook up an MCX box or an Boost-IT, but as i said, according to Scott it can be done, on an Apex engine!
Adrenaline Addiction
MRFUSION said:Hi there guys, been running my Nypex for 2 years now with great success and I will be looking to upgrade my fuel system for next season. I have been running the Boondocker box with good results but looking to go stand alone or an aux injector style system. I run about 16 psi on my Apex engine which is probably maxing out my stock regulator and injectors, I run a little lean it seems on long pulls. I run Daves Meth system and he modified my stock injectors slightly for more flow. Runs clean but looking for improvement. Any suggestions, Boost it, Impulse or anything for more mountain running? Thanx guys. Shad
The Boost-It system rocks on the Apex motor. No need to change timing on the Apex for mountain riding. Run the stock fuel injectors and the stock ECU for great throttle response, let Boost-It fuel your boost. Stupid simple and flat out works. Best part is, its located right here in AB !!
- 6K
