No show
I am going to be doing a track extension on my 2012 Phazer GT, going from a 121 to a 144. I have read lots of posts on this and there is lots of good info but, I am confused. So I am asking what would be the best thing to change first? Gearing, driver or clutching. 95% of my driving is on trails or stubble fields.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
My son didn't change anything on his 09 GT when he extended his.
No show
Good to know, thanks for the reply.My son didn't change anything on his 09 GT when he extended his.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
With a GT you should have a 20t upper gear, I'd probably opt to install an MTX axle and drivers (cheap on ebay). It kills 2 birds with one stone by lowering your gear ratio AND giving you some adjustment. With short track drivers installed a 144" will be VERY tight with the adjusters loosened all the way. With 20t upper you will STILL geared to do 85mph+ with MTX drivers.
No show
That is an eight tooth driver?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
yes, I have a 9 tooth Trail axle/drivers I tried to install on my MTX for a better approach angle but I couldn't get the track loose enough with a new track with those drivers. Maybe extensions on a 121" rail might be a bit shorter, this is with my factory 144" rails (which uses the same suspension components)That is an eight tooth driver?
