No show
- Nov 10, 2011
- Rouleau, Sask
- 2012 Phazer GT
I am going to be doing a track extension on my 2012 Phazer GT, going from a 121 to a 144. I have read lots of posts on this and there is lots of good info but, I am confused. So I am asking what would be the best thing to change first? Gearing, driver or clutching. 95% of my driving is on trails or stubble fields.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
My son didn't change anything on his 09 GT when he extended his.
No show
- Nov 10, 2011
- Rouleau, Sask
- 2012 Phazer GT
Good to know, thanks for the reply.My son didn't change anything on his 09 GT when he extended his.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
With a GT you should have a 20t upper gear, I'd probably opt to install an MTX axle and drivers (cheap on ebay). It kills 2 birds with one stone by lowering your gear ratio AND giving you some adjustment. With short track drivers installed a 144" will be VERY tight with the adjusters loosened all the way. With 20t upper you will STILL geared to do 85mph+ with MTX drivers.
No show
- Nov 10, 2011
- Rouleau, Sask
- 2012 Phazer GT
That is an eight tooth driver?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
yes, I have a 9 tooth Trail axle/drivers I tried to install on my MTX for a better approach angle but I couldn't get the track loose enough with a new track with those drivers. Maybe extensions on a 121" rail might be a bit shorter, this is with my factory 144" rails (which uses the same suspension components)That is an eight tooth driver?
- 10K
