arteeex
sledsearcher said:How in the H$LL are you guys able to mount the bolt in the front most hole? It took everything I could do to get them to mount in the center hole. The stock rubbers just wont line up to allow it. The rubbers are absolutel jammed to fit inside the angled aluminum pieces.
Blow on it.
You're sure you have the V2 or V3 mounts on your Simmon's? If so, lay the ski rubber in place, get the ski started on to the spindle with the spacers and bushing in place. Then lower the sled and use its weight to help compress the rubber. I used a larger Phillips screwdriver (smaller than the ski bolt) as a drift pin to help align the holes. It went together pretty easy with this method. When I moved to the forward mounting hole I cut a small chunk off the front corners of the rubber to make space for the nuts that hold the bracket to the skis.
There's a photo at the link below.
http://www.ty4stroke.com/viewtopic.php?p=708130#708130
