scar
This is my first time checking my spark plugs on my Apex.Do the caps just pull off the spark plug or is there a trick to this?
sawsalesman
You have to unscrew the cap. The cap is screwed down into the top of the head. Take out the screw and then pull off the cap. This will allow you to get the spark plug wrench into the hole.
scar
So when you say unscrew the cap do you mean take the bolt out that is holding the cap on and then pull the cap out?
sawsalesman
You got it!
scar
So is there a trick to pulling these caps off or just pull hard.I just finished changing my oil and filter and that was a journey in it's self.
