rage man
i notice the plugs are easy to get at on this not like the apex and i was wondering if when you put the trail tank on it takes the ease out of this and you have to take the tank out to change the plugh thx
Gibby
- Jan 28, 2005
- Jackson, Michigan
- www.fitzgibbonstruck.com
yes you have to remove tank to change plugs.
rage man
dam now i dont want the tank
stinx
Get the tank, I have one. To access the plugs you just need to unbolt the tank,then slide it back. 6 bolts total to do this if I remember correctly. 2 bolts for the side covers, 2 bolts for the seat and the 2 bolts that hold the tank in place.
rage man
how much would that suck at -20 on the trail at 12 at night when you foul a plug and i know its a 4 stroke but fouled plugs are not un heard of happend on my rage
Gibby
- Jan 28, 2005
- Jackson, Michigan
i have never heard of fouling a plug on a 4 stroke when cruising down the trail, the only time i fouled plugs on my warrior was when i would start it and not warm it up completely then shut it down the next time i would go to start it they would be fouled
stinx
The only time I ever fouled a plug was on my warrier when I fired it up then shut it down instead of letting it warm up properly. 5000 miles on my Attak and nevr fouled a pllug- I will take my chances with the trail tank
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
ur rage was carburated too dont forget, less chance of fouling with fuel injection. I had a rage 2 and fouled 1 but the carbs were dirty. im thinkn about the trail tank too and changing the plugs is not really a priority to me. Still in the two smoke frame of mind?
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Since it has been so long since I have had a stock tank. Can you reach the plugs with a universal, or do you have to screw with the tank like a trailtank? Someone pm'd me about this, and I wasn't able to answer his question 100%
dirkdiggler
Suspended
rage man said:dam now i dont want the tank
the chances of Fouling a plus are slim to non. The Chances of running out of gas with a 7 gallon tank are pretty high!!! LOL
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
That is what I told him. The only time I fouled a plug is when I was stupid. When I first got it I didn't let it warm up enough. Can you say dumb a$$
