CRH07
- Nov 28, 2015
- Minnesota
- 2006 Yamaha Apex
Recently my drive axle bearing and speedometer sensor had gone out. After replacing them it is now showing a check engine light, error code 20. Could this be caused from changing out the sensor and I need to reset the codes?? If so does anyone know how??
Thanks!
Thanks!
http://www.ty4stroke.com/attachments/fault-codes-jpg.77941/
Looks like the air box sensor.. but there is more info in the Apex FAQ
http://www.ty4stroke.com/threads/apex-attak-frequently-asked-questions.42869/
Also here is how to clear codes:
http://www.ty4stroke.com/threads/how-to-clear-codes-on-attak.73896/
CRH07
- Nov 28, 2015
- Minnesota
- 2006 Yamaha Apex
Yeah, I took a look at the sensor. It has an MPI supercharger so the sensor is tied off to the side not in use. Everything appears to be functioning correctly, I am going to try and clear out the codes. Thanks!
ok, makes sure the sensor is still plugged in.
