snowmotion
my RX1 Guages have Suddenly partaily stopped working
seems to be just odometer & Speedo
any solutions or suggestions? I can find no obvious problems with the wiring all connecters look good
RX-1MAN
Did you check the connector at the pickup below the secondary clutch? I would look there if all other indications are working normally.
VT_Wethead
Isn't that the first sign of a bearing going bad?
black john
bearing
check the drive shaft bearings
