webzwarrior
just bought a 04 warrior a couple months ago. rode it for the first time in the first snow and the speedo stays on zero. the miles dont go up either. replaced the speedo sensor and the problem still exists. checked the wires on the back of the cluster and those are all good. rest of the cluster works great except for the speedo and odometer. would new driveshaft bearings fix the problem? thanks for your help.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Is the little gear like thing still on the end of the drive shaft near the sensor?
webzwarrior
yes that little gear is still on the end of the shaft.
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
Sounds like you have an issue with either the gauge itself, or the ECU may have a fault. You may have to have your dealer hook it to the comouter to diagnose that one..
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
There is a speedo/odo fuse on the RH side its 10amps. Its located in the little fuse box that contains like 5 fuses. Check that.
Len Todd
There is no fuse in the Speedometer Sensor circuit. There is a gage power fuse. But, the whole gage does not work if that fuse goes. As I read this, it just sounded a bit confusing. But I let it go. Then there was another post that made reference to this post reading like there was a fuse in the sensor circuit. So, I came back and clarified this.
So webzwarrior: Is the whole gage dead or just the Speedometer and Odometer?
webzwarrior
it is just the speedometer and the odmeter... the tach and all the lights work.
Len Todd
Assuming you have tested the sensor and checked the connection at the sensor end, most likely the gage has a problem. Anybody around that you can swap gages with for a test?
webzwarrior
nobody that i know of. all of my friends have 2 strokes.
i changed the sensor because that is what i was told was wrong by a local dealer. put the new one on and nothing changed. that same guy also told me that it could be the bearings but i havent changed those or looked at them. the connection to the speedo sensor is fine and everything looks how it should...
Len Todd
Well, ... you might want to consider looking at the PTO Drive Shaft bearing. If you are not sure it is good, how can you be sure your are not messing up the new sensor? I guess I figured that this was obvious. But, I guess not. Sorry, I did not pick up on you not checking the bearing.
webzwarrior
Len Todd
You might want to get back to the bearing before you ruin the new sensor.
But to answer your question; If the ODO is working but the Speedo is not, then you have a gage problem.
webzwarrior
it is both the odo and the speedo that are not working...
