snow scooter
- Sep 25, 2022
- saskatchewan
- 2009 yamaha rs venture gt
just purchased a 2009 venture gt speedo stays at 0 bearing is good and speed sensor looks fine i had a bunch of stuff apart checking wires and making sure things are plugged in before i checked it over i had no codes now i have code 42 and code 84
theCATman
- Feb 19, 2007
- WI
- Yamaha
Speedo sensor is junk. Replace it and TORS code 84 will go away after replacement.
They go hand in hand. If the ecm doesn't see a speed readout after a certain rpm is reached, it'll throw TORS on for "safety"
snow scooter
- Sep 25, 2022
- saskatchewan
that's what i was maybe thinking of getting a sensor i can see pieces of belt in the area and a new belt on it maybe the belt came apart and hit the sensor possibly
even with both codes flashing it still runs and drives fine
theCATman
- Feb 19, 2007
- WI
- Yamaha
It will, until you'd let off the throttle and try to go again. Then TORS will kick in and it won't move.
I had a sensor croak once on my Nytro. I bypassed TORS and rode with no speedo for a week til new sensor arrived. That was middle of the season and wasn't gonna miss out on any riding.
Dara
- Jan 24, 2007
- Sault Ste Marie, Ontario, Canada
I had the same thing as what catman says on a brand new 2012 Vector. Same codes.
It would still go if you feathered the throttle down but if you let right off you had to come to a complete stop and start again.
It was kinda dangerous on some fast trails in Michigan when you let right off in a corner.
Took the dealer a few tries to figure it out.
snow scooter
- Sep 25, 2022
- saskatchewan
i got that sensor on order how do i bypass the tors
usually gets bypassed down by the throttle bodies/carbs. where the throttle cable mounts there, there are 2 wires. just unplug them and plug them together.
snow scooter
- Sep 25, 2022
- saskatchewan
used it for about half a tank with the codes blinking at me and no speedo lol new sensor came in yesterday and now is good as new
