hognit09
- Mar 7, 2010
- beaver dam, wi.
- 2016 viper ltx le,2016 viper ltx dx
While having shocks rebuilt noticed right side ski had play back and forth. Got new bushings and pin, but cant get the bushings out of spindle. There are 2 in each spindle and a seperation between them, any ideas?
Turned a piece of aluminum to act as a punch on the bushing OD. Then they tap right out.
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
Find the seam in the bushing. Then stick a small pointed chisel of screwdriver in between the bushing and the spindle, bending it into the hole. Once you have enough of it bend in, then grab it with a needle nose pliers, twist, and peel them out. To install the new ones, take the factory ones, return them to the dealer for a refund, and send a pm to UPBushman, and get his kit. Stock ones are JuNk!!
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
here you go: Spindle bushing removal and upgrade
