AttakDog
Just replaced the ski spindle bushings with the Mcmaster Carr ones, tightened the ski spindle mount up nicely. While it was up noticed the upper a-arm bushings are crap and the lower ball joint is also. 1,260 miles this year so far, 1,605 total. I knew from reading on here to watch those areas but just can't believe they go bad so quick! So now $150 for the lower ball bushings and $200 for the Ulmer a-arm kit. Which should I do first?
AttakDog
Sorry I guess the Ulmer kit is only $86 but it looks like it's out of stock. Where can I get the ball joint bushings (I am in MI)
arteeex
I know a guy that can hook you up with ball joint bushings. Try sending a note to info@northcoastinnovation.com.
Tell him arteeex sent you. This won't get you a discount but it makes him feel needed and appreciated.
mytro
arteeex said:I know a guy that can hook you up with ball joint bushings. Try sending a note to info@northcoastinnovation.com.
Best replacement parts used this year.
AttakDog
Thanks guys!
