CustomApexMan
Does anyone know how to get in to diagnostic mode and adjust the CO number for idle fuel ratio like you can on apex and nytro? I have mcx 270hp and would like to lean the idle up.
You go into diagnostic mode by holding the left and right lower buttons down but I do not believe co can be adjusted.
Anyone?Does anyone know how to get in to diagnostic mode and adjust the CO number for idle fuel ratio like you can on apex and nytro? I have mcx 270hp and would like to lean the idle up.
May not be possible. Havent found a setting in diagnostics.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Not possible with the Cat ECU.
CustomApexMan
I ended up being ok once I put the air cleaner through the hood. I strongly recommend through the hood intake there is no comparison vs under the hood way more power so much more it was hitting the Rev limiter
