SR Viper Snow Check Turbo Buyers, upgrades are available!
Srxspec
Ulmer Racing
Tech Advisor
Menno, SD
Website
www.ulmerracing.com
2014 Yamaha SR Viper LTX, 2014 Yamaha SR Viper RTX SE, 2015 Yamaha SR Viper MTX SE 162 (turbo), 2015 Yamaha SR Viper MTX SE 153
LOCATION
Menno, SD
WEBSITE
www.ulmerracing.com
Mountain Elevation Riders
  • Intercooler Upgrade, Part # MTV-1100 $1449.00
    To control intake temps above 7 lbs of boost I would recommend a intercooler, this also comes with a billet blow off valve, quicker response waste gate, etc.
  • Fuel Pump & Regulator Upgrade, Part # HSK-1168 $319.95
    In order to run above 8 lbs of boost at 6,000 foot elevation or higher, a fuel pump and regulator upgrade is required, this is for the guys who really want to turn up the boost.
  • 4th Injector Kit Upgrade, Part # HSK-1169 $449.00
    The stock injectors will run out of fuel around 10-11 lbs of boost when used at higher elevations, this 4th injector kit will allow you to max the turbo out and still supply plenty of fuel.
Sea Level Elevation Riders
    To control intake temps above 6 lbs of boost I would recommend a intercooler, this also comes with a billet blow off valve, quicker response waste gate, etc.
    In order to run above 6.5 lbs of boost at low elevation, a fuel pump and regulator upgrade is required, this is for the guys who really want to turn up the boost.
    The stock injectors will run out of fuel around 9 lbs of boost when used at low elevation, this 4th injector kit will allow you to max the turbo out (14 lbs) and still supply plenty of fuel.
  • Also for you low elevation riders, I have a head shim which will drop your compression ratio from the stock 11:1 compression down to 9.5:1 compression. This will allow you to run 9 lbs boost on 91 octane fuel and if you can continuously get good 93 octane fuel you could run 10 lbs of boost on pump gas. This kit includes a head shim & ARP head studs and is $279.99 for everything.
