SRX wont start after storage
SRX’er
Nova Scotia
Canada
2021 SRX
Just went out to flash up my 21 SRX, im considering trading it for a 25 SRX, fuel pump is working put some fresh fuel in the tank but it will not start, i did disconnect the battery for the summer and sled hasnt been started in 5 months, i expected it to be alittle cranky but it seems to not wanna flash up at all.
Battery is on the charger
Any tips?
Just keep cranking till it goes?
Check the obvious first, kill switch in the on position, at least 10-15 litres of gas in the tank, no loose connections hoses plugs etc and all fuses good. If all good check if fuel is reaching the return line and you have spark. I’m no mechanic but I’d probably start there. Hopefully she fires up…
Ahhh.. i got it, i had drained the fuel and didnt put enough back in for the fuel pump to pick it up(sled stand lifting the rear suspension)trip to the garage for some more fresh fuel and she flashed right up lol!
Wish everything was that simple to fix lol
