Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
Anyone know a cure for this. I posted this last year and lots have the same issue. I'm talking about a hesitation if you stop the sled and full throttle it. There's a bog then she goes. No other issues.
MikeWalters
I had this problem until my secondary clutch was fixed up.
Ruggybuggy
- Sep 1, 2013
I'm running a new upgraded secondary.
MikeWalters
other mods? exhaust or intake?
what helix and spring do you have in the YVX secondary?
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
Any recent mods done? Pipe?
Ruggybuggy
- Sep 1, 2013
No recent mods and I'm running a Vector secondary with a green spring and 43 helix. Also have Ulmer's primary clutch kit. It's just a annoying 1 second bog then goes. I wonder if a 41 helix would make it worse or better?
Also should add I'm running the 9 tooth drives. 144 track and FX gears.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Have you considered dropping a tooth or two?
Ruggybuggy
- Sep 1, 2013
On the drive sprockets? I don't what to loose top end and I like the better approach angle of the 10T. I was thinking a different helix because it would resist the belt digging down to far in the secondary.
canoehead
- Jan 14, 2011
- NE, Alberta
Not the drivers but the gears.
Ruggybuggy
- Sep 1, 2013
Same result though and I would loose my top end. I'd sure like to see if that belt is digging into the secondary and causing it. Those running the YVX secondary, what helix are you running. I'm also thinking of running a variable ramp helix something like 39 and ending with a 51. Best of both worlds.
