Star kit seems very bouncy
coolio
I just installed the star kit in my 14 apex xtx and it seems like there is very little rebound damping and not much compression damping either. If I push the rear bumper all the way down and let off it bounces right back up all the way to the stops with a clunk. Something just seems wrong. I had them rebuild and revalve my shocks and I installed the skidoo center shock spring. Is this the way its supposed to be? It does move smoothly and easily though and that's a big change from stock. I don't know how much preload to run on the center shock so I set it at 125mm measured the Yamaha way. Is this right?
Just try and Ride it ..
If your still unhappy call him up and talk.
My 13 XTX with Star bounced up but short of full stroke which I viewed as improved as pre Star it left allot of un used travel
I think you will like the ride
Per Star suspension's advice I took the sleds off the casters it was on and put it flat on the floor of my shop. The rebound is less dramatic so hopefully all is well. I should be able to ride it a little next weekend possibly.
Tell him Yamadoo! It's a sweet ride once you get it dialed in.
Yes guys, it rides great! It just was acting wierd when on casters I guess. The suspension is actually comfortable now and I now longer grimmace when hitting a sharp bump at speed.
