Ffbsy
Hi I have been looking through other posts and at the star suspension site (with no luck due to it not being in English) but I would like to do the 128 kit but I would like it to be a 136 does anyone know if they sell the xtensions to make it into a 136 or if I have to buy a 128 to 136 from somewhere else. Also if anyone has any opinions on doing this it would be appriacated. last thing is I see a lot of the xtx riders are having limiter strap issues with this kit. Is this also an issue on the shorts? If so do I need to send my shocks into them also. Any help would be great
shadow44
Buy extensions from Tracks USA to convert from a 121 to a 128, then buy the star suspension 128 relocate kit. There is a member on here who has done it and say its great. YOu will also need to buy a tunnel extension from Tracks USA.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I did the 128" Star relocate on my 08 RTX and now have 2000 miles on it. So far I'm very happy with the results and have had no problems with the suspension. I also installed the Hygear Dual Rate spring with the crossover option on the center shock which compliments the relocate. Installing a rail extension kit and a 136" track with the relocate shouldn't cause any additional problems although I would add another set of idler wheels toward the rear to reduce hyfax wear.
here's some info: http://www.ty4stroke.com/viewtopic.php? ... ension+128
Ffbsy
shadow44 so does the setup you said above put me at 136" inch mark then? just double checking that I am understanding right. Grizz have you had any issues with your limiter straps like the xtx guys are having
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Re: 136
I think there's some confusion between the 128" and XTX Star suspension kits. The 128" kit is for relocating the skid to accommodate a 128" track. It also decreases the track's approach angle which reduces the harshness of hitting bumps. You can install both the appropriate length rail extensions and the Star 128" relocate kit together to accommodate a 136" track or install just a 136" rail extension which will leave the approach angle as is. The XTX kit is not a skid relocate kit but more of a shock relocate to soften the ride without bottoming out. The XTX is obviously harder on the shocks and limit straps with all the reports of failures. After 2000 miles with the 128" kit I have had no problems with shocks or straps and have nothing negative to say about the kit. I think the decreased approach angle and longer track is an excellent improvement over the stock setup. For trail riding I think the 128" is perfect and really don't see the need to go to a 136".
Which browser are you using? You can translate the Star Suspension website to English.
Ffbsy said:shadow44 so does the setup you said above put me at 136" inch mark then? just double checking that I am understanding right. Grizz have you had any issues with your limiter straps like the xtx guys are having
rough rider
The problem with the shocks and straps on the xtx is that they were breaking before people put the star kit on, when straps wore through from rubbing or catching on track lugs they break and cause the front suspension to drop down and cause rear shock to flip over, it can happen to any 09-13 nytro xtx regardless if star kit is installed or not,
shadow44
Re: 136
I believe it does put you at the 136" mark...I wish I could remember who on here did it...hopefully he will chime in. I will look for his post so you can pm him.
Ffbsy
Star
Thanks for the help guys and grizz I am using my iPad now but is will try my pc and see if that will translate it. On a side note grizz I was wondering about how much wait is added with your subframe kit
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
approximately 1 lb added if you gusset the frame.
xrrider
Re: 136
I did the Star relocate and Tracks USA rail extensions. Best mod I have done so far to this sled. You can PM me for details and pictures if you want.
shaddow44 said:Ffbsy said:shadow44 so does the setup you said above put me at 136" inch mark then? just double checking that I am understanding right. Grizz have you had any issues with your limiter straps like the xtx guys are having
shadow44
Re: 136
Lol...a good fellow TY'er would post them up for all to see
Not sure if I've asked, but hows the handling with the add length to a 136..being that they are not tipped up?
xrrider said:shaddow44 said:Ffbsy said:shadow44 so does the setup you said above put me at 136" inch mark then? just double checking that I am understanding right. Grizz have you had any issues with your limiter straps like the xtx guys are having
Not sure if I've asked, but hows the handling with the add length to a 136..being that they are not tipped up?xrrider
Shaddow, not sure of the difference between the tipped up rails, I have never rode a sled with them, but it rides a lot better than when it was a shortie.
The pics I have are too large to post here and I can't figure out how to re-size them, but anyone wanting pics can PM me with their email address.
