Eric4440
- Jan 15, 2018
- Hudsonville, MI
- 2014 Viper XTX
Going through the 14 XTX I just bought, decided to tackle the sloppy steering issue, tightened the nut and it helped but only a LITTLE, when the bars are turnedd all the way to one side it has about 2-3 inches of slop... I noticed that the pitman arm where all the linkages connect to is actually sliding up and out of the bushing till it hits the aluminum bracket above it and has ground into it from turning the bars riding. I CANNOT for the life of me see any issues causing this to happen, is this just the design or is there a retainer or something that is supposed to keep that pitman arm all the way down and prevent it from sliding out of the bushing?? here is a photo of the pitman arm and bracket and you can see where its been grinding into it.. I also made a video of the pitman arm sliding in and out of the bushing if someone needs to see what Im talking about. I feel like theres something I'm missing...
Hopefully someone can steer me in the right direction I was hoping to go riding this week
https://drive.google.com/open?id=181voPzAvh5Po0SFKPFzIN3_vkG7fDXyC (Photo is upside down)
