Dalton
- Mar 13, 2013
- Chippewa Falls, WI
- Sidewinder XTX SE 141
Yamaha Phazer 2007 GT
Hey all,
So I took a trail pass off my windshield, then use goof off to get rid of the white sticker residue which I regret painfully.
It smeared all over the windshield. I've researched WD-40 methods, fingernail polish remover using a rubber blade to scrap it off to no avail or at least not getting it better.
Any methods I'm overlooking? Its the orange windshield and I also can't find where a guy would buy a new one of them online.
Thanks!
Thanks!
DirtFarmer
- Aug 13, 2017
- Galloway, NJ
- 2009 Yamaha Nytro R-TX SE
I’ve used windex in the past. Spray a lot on and let it soak. Take a flat razor blade and carefully scrape it off. Comes off nice and easy and no mess.
Sent from my iPad using Tapatalk
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Plain old gasoline.
rlbock
Goo gone works great on windy, goof off is way to aggressive for plastic, it will melt most plasticsHey all,
Thanks!
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Ditto rlblock. Stay away from goof off . Eats some plastics up
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Usually 91% iso alcohol is always your best and safest bet for any graphic..If tough, soak several layers of paper towel and let it lay on there awhile.
Windows are the worst though, easily damaged.
Epicsw
- Sep 27, 2016
- Fort Atkinson
- 2017 Sidewinder
My Ontario, Canada pass destroyed my window as the adhesive spread out 50% larger than the sticker itself when using chemicals to remove the remnants. Dealer took pics to share with the state of WI so they understand what a problem some of these trail pass stickers can be.
dgjr636
- Nov 16, 2013
- Clarence NY
- Sidewinder LTX LE
As a dealer we run into this all the time. Best thing we have used is heat, duct tape and Plexas Spray polish. We can get the passes and stickers off the windshields with no scratches 98% of the time.
1) Heat with heat gun or hair drier till warm.
2) slowly pull off pass or decal.
3) use good strong duct tape and blot this area fast, sticky part of tape on window. I like to make a backwards roll around my hand. this should lift off most of the glue residue.
4) use Plexas spray polish to remove any glue residue left. I use a Healthy dose in this area and let sit for a few minutes. I agitate with fingers ( not finger nails). Then wipe clean with a microfiber towel.
This Spray polish does not seem to have any harsh chemicals in it that would dull or scratch the surface area.
Plexas Spray polish works wonders on just about the entire sled for cleaning and polishing. It’s not cheap $20-$25.00 per can but us a must in our shop.
Yamatario
- Jan 8, 2009
- SW Ontario
- 2018 LTX SideWinder
2015 Viper LTX DX
2009 Nytro XTX
Brake cleaner.
dgjr636
- Nov 16, 2013
- Clarence NY
- Sidewinder LTX LE
Most brake cleaners will destroy a windshield. I would not recommend.
If you have a specific brand that has worked for you without any damage please share.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Winner, winner, chicken dinner.
Hair dryer and duct tape. All you need.
I agree, Plexus is the bomb. Good thing a little goes a long way.
dgjr636
- Nov 16, 2013
- Clarence NY
- Sidewinder LTX LE
If you are past of no return on your SW window here is the window you need to order.
8MG-K7210-10-00. It is on backorder until 2/19 from Yamaha.
2017 Yamaha Sidewinder RTX/LTX SE.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Have had good luck with Goo Gone and a little patience rubbing it off with a soft cloth.
Goof Off is basically the same as raw Xylene like you can buy in the white and yellow Sunnyside can at the hardware store.....too harsh, ,made to remove solvent based epoxy paints. We buy that in bulk at my work.
Old Man 5
- Mar 21, 2017
- sudbury,ontario
- sidewinder RTX 50TH
Old Man 5
- Mar 21, 2017
- sudbury,ontario
I use lighter fluid works great.
